DAVID'S WEB SITE
Date:  7-3-2014
Number of Hours:  6.00
Brief Description:  Door Seal Work
I worked on what passes for a door seal on the fuselage. Some of the seal pieces were too worn out to re-use so I had to fabricate several pieces of strip material. I tried to incorporate the rubber door seal material that some planes have, but had real door fit problems and decided it was not worth it. I may still try to find a smaller version of the "P" seal material and fit it later. Otherwise, the fit is complete.
Door seal in place.
Door seal in place.
Checking door fit with seal in place.
