DAVID'S WEB SITE
Date:  3-10-2013
Number of Hours:  3.50
Brief Description:  Cowling Work
I removed all the cowling pieces from the engine area and did the necessary edge trimming to get all the edges to line up nicely. I dressed all the bolt holes and fisheed all the edges and corners. These pieces just need cleaning and they're ready to prime. I also removed the generator and its mount frame. I discovered a crack in the mounting frame and want to weld that crack before it becomes a problem.
Piper badge mounted on the new side cowl pieces.
First fitting fo the carb air box baffling. Trimming still to do.
New cowl pieces all done and ready for cleaning and priming.
