DAVID'S WEB SITE
Date:  2-2-2013
Number of Hours:  1.50
Brief Description:  Side Cowling Pieces Mounting
I started work on mounting the new side cowl pieces. I used a technique that I found sucessful when I mounted my new leading edges on my wings. After I attached the side pieces at their bottom points, I took cargo straps and gently pulled the top edges into place. This held them pretty close to their final position as I drilled the holes for their screw locations. It also made sure the front edge of the side pieces fit nicely around the trailing edge of the nosebowl. I finished the left side, and did all the marking for the right side.
The left cowl side piece pulled into place and ready for drilling.
Left side all drilled and screwed into place
Measure and mark, measure and mark....
