DAVID'S WEB SITE
Date:  10-13-2011
Number of Hours:  2.50
Brief Description:  Fuselage Covering Work
I finished the work on the reinforcing patches for the different fuselage areas. Also, I started looking at raes I need to finishe up before the covering makes things more difficult, and decided to go ahead and mount the two brake master cylinders onto the floor. Also, while I'm in the neighborhood, I might as well go ahead and mount the heel kick pads for the four brake/rudder. positions. The brakes had to have their final clean-up and I neded to modify the shape of the front kick pads, so I worked in that direction for a bit.
Re-enforcing patch for the fuselage  handle.
