I finally tackled the task of hooking up my ailerons. I connected the cables and then started the process of rigging them. There are a total of three turnbucles that provide rigging adjustment to the cables. If you adjust one, it affects the other two, so getting the stick centered with the ailerons lined up and tight is a trick. Actually, it was an exercise in patience and perseverance, but I just kept working at it until it was where it needed to be.
