After being gone for about ten days, I finally got back in the hangar and started bolting everything down from the wing install. I started with the cabane struts and worked through the installation and tightening of all the bolts associated with those items. That's a lot of cotter pins! I made a list of the items I would need for hooking up the fuel tank pick-up and vent lines, along with the pitot and static lines coming out of the left wing. Next session, I'll start fitting the new wing root fairing bottom pieces and start on the wingtip nav light install.
