I decided to brave the heat in the hangar and get some more work done. I installed the last of the inspection rings on the left wing. It's ready to mount on its wing rotisserie. I also started with the last of the fabric on the bottom of the right wing. I glued down the leading edge seam, ironed it into place and then did the final gluing.
Inspection ring beside a jury strut opening.
The bottom fabric laid out on the right wing. Leading edge is tacked down.
