Brief Description: Wing Parts Clean-up and Wing Tip Work.
I finished up on the bracket mounting work on the left wing tip. The tip bow is now ready to take back off and varnish. Also, I started putting back together the compression strut group where the wing struts attach. The strut attach points go into place first and then compression strut itself. Working out all the alignment issues is fun, as always. Basically, it's just an exercise of installing and removing bolts unitl it gets ridiculous, then you know how it should have fiited all along.
New left wingtip bow almost finished.
One of the wing strut attach points back in place.
