Since the end ribs of the of the wet-tank are 0.032" the pressboard aft-rib forms seemed a tad fragile fpr this thicker material, although they've worked well enough for the 0.025" ribs, I made another set of aft rib forms for both the 0.025" and the 0.032" 2024, so now I need to finalize their shape and then put in the appropriate bending radius as well as flutes and will yet need to build in the Callbie Wood joggles near the spar caps.
