Finished up the rudder skeleton build. I had to trim the R-710 rudder brace per the plans. I'm not sure how it would have turned out without the help of Vansairforce.net. I was just reading on there how most builders have to order another one of these and redo it, because the dimensions given on the plans aren't 100% accurate. So armed with that advice, I was able to get everything to fit on the first try.
