DAVID'S WEB SITE
Date:  11-3-2017
Number of Hours:  2.50
Brief Description:  Installed Garmin GSA28 elevator pitch servo
Marking the location of the aft set of rivet holes was a challenge as the is not much room to for the rivet to sit with proper clearances. Once the holes were located things moved much quicker. The holes were match drilled and then 10 AN470-4-5 rivets were driven by my wife while I struggled with the tungstun bucking bar in the small space. Turned out very nice. The actual mounting of the servo was very easy.
Rivet holes located, marked and match drilled.
10 Rivets driven to secure the servo bracket.
Servo mounted and drive arm attached to belcrank.
