DAVID'S WEB SITE
Date:  10-31-2017
Number of Hours:  1.00
Brief Description:  ELT Mounting Bracket
I only had an hour to work on the RV-8 so I decided to start on the ELT mounting bracket. I took some measurements where I wanted to mount the ELT in the aft fuselage and then drew up a full size plan of the of the angle supports I would need to mount to the mid and lower longerons. With the correct measurements I cut the 4 pieces of 3/4 inch angle stock to size. I trimmed the side supports so they would lay flat on the uppper and lower supports. Then I deburred all edges for the next day.
ELT Bracket mounting hardware.
