DAVID'S WEB SITE
Date:  4-1-2016
Brief Description:  Duckworks Taxi Light Right Wing Part 1
Installed the Duckworks taxi light in the right wing.
Marked the hole location with the templet and marked the mounting screw holes at the same time.
Started a hole with a #30 and the increased with a unibit.
Cut the rough hole with the pneumatic nibler.
Trimmed hole with the pneumatic die grinder with a cutting wheel.
Fine trimmed with a dremel tool and cutting wheel.
Smoothed edges to the outline with the die grinder and a scotchbrite wheel.
Starting a hole with a #30 bit.
Cutting with the Dremel tool
Edges trimmed and smoothed with scotchbrite wheel.
