DAVID'S WEB SITE
Date:  2-10-2016
Number of Hours:  3.50
Brief Description:  Finishing the flap hinge, adding aileron stop.
Today Parker and I riveted the left and right flap hinges into place on the wing trailing edge. We made a bushing out of delron rod and drilled a hole in the middle to slip the aileron attach bolt through. We removed 4 flap hinge loops and cut the hinge pin into two pieces. Now the pin is much easier to remove and can be secured in the middle of the flap.
Flap hinges installed.
Delron aileron stop added.
Flap hinge pin cut into two pieces.
