Brief Description: Riveting rear and forward spar assemblies.
Today I riveted the HS rear spar HS-603 and the rear spar reinforcement bars HS-609 together. Next the hinge brackets for the rear spar were riveted into place. The HS-411PP Center Bearing was bolted to the rear spar and torqued to the correct value. Next I started riveting the HS forward spar channels HS-702, with lthe spar doublers HS-00003 and the forward spar reinforcement angles HS-810-1(upper) and HS-814-1(lower) seen in image #2. Its amazing how rigid this structure become when the parts are riveted together.
Rear HS rear spar and the two reinforcement bars being viveted with pneumatic squeezer.
Forward HS spar components being riveted in place.
