Davids Web Site
RV-8
Firewall/Engine Ground
Located, drilled holes for the firewall grounding block. Cleaned up holes and mounted grounding block. Started running the wires for the Left P-Mag Ignition. Installed Three Cushion Clamps to retain the wires along the firewall midline.
Firewall Grounding Block
Running Left P-Mag wires
RV-8 Home
678
Brake System
Electrical Wiring
Elevator
Fundamentals Class
Fundementals Class
Fundementals of Buil
261
Practice kit
