Brief Description: Flap actuator and flap motor assembly
Drilled the #12 holes in the flap motor attach bracket and F-807 bulkhead. Drilled 1/4 holes in the three clevis attach points on the flap actuator weldment. Painted the flap motor attach bracket and the flap actuator weldment to match the fuselage. Installed the flap motor attach bracket with AN3 bolts.
