Tonight I sealed the trailing edges of both right and left elevators with pro seal and cleco'd them to the their respective aluminum angle straight edges.... a few days from now when the sealant has set up i will rivet them shut via the double flush method.
Once complete with this I dove into the trim tab. I started my masking off the areas where the foam blocks will be adhered to the inside of the trim tab skin. Next I fabricated the foam blocks and wood clamping blocks.
