Derek & Kims RV-9A Build Log
Date:  5-4-2012
Number of Hours:  1.00
Brief Description:  Re-Start Trim Tab Construction
Received replacement parts for trim tab. Cut the control horn attachment as indicated for manual trim and match drilled to the skin. Sanded the inside of the skins where the foam spacer blocks will be adhered. primed the interior of the skin and the control gorn attachent.
