Derek & Kims RV-9A Build Log
Date:  4-13-2012
Number of Hours:  4.00
Manual Reference:  6-4
Brief Description:  Rudder Assembly
Tonite I dimpled all the ribs, spars, parts and skins. Had to get creative to dimple a few of the tight spaces near trailing edges of the ribs. I used a rivet puller with a dimpler set and stacked some square washers in the space to pull against. This tool will pull a dimple in from the opposite side, which works well where a yoke will not fit.
I also assemble the skeleton of the rudder using the pneumatic riveter for 98%. This worked real well and provided perfectly set rivets. I also was able it get creative near the bottom attach bracket and horn brace and use the pneumatic for all but 1 rivet at the forward edge of hte bottom rib/horn bracket. The plans allow for optional pop rivets here.
Using washer as shims to dimple tight quarters with the rivet (dimple) puller
Rudder Attach Bracket
Optional Pop Rivets in bottom horn Bracket
