As I was working on fuel lines it seemed a good idea to get the brake lines in place now. I have SS lines, no plastic. Its something I want to install without any concerns.
I ran the lines both sides and then use micro and 1 ply of BID to secure them to the fuselage sides. They are just exiting at both ends for now. It does mean I can get on with putting the fuel system in place.
I had to add some foam fillets in the rear exit area so the lines would sit without strain. I really would like to do it all again a be a bit tidier. The micro on the fuselage sides doesn't look pretty. No one will see it except me, which is not the point.
