Installed the left Bellcrank and mounts today, went very quickly and all bolts received torque value of 20 inch lbs as per Section 5.
Bellcrank tested free and easy with Boeing lube for lubrication.
Drilled this one out with the air drill which turns faster and made for a nicer finish inside the brass bushing, even though the turning is done on the outside of the bushing while flying
