Took a few hours out today to install the pushrod from the Trim Tab servo. Left lots of pushrod inside the clevises if needed. Installed the cotter pins in both ends. and locked the pushrod in with the locking nut. Had to cut a small chuck out of the lower skin to allow the servo to slip inside the elevator.
Went well and tried the servo motor out , first animated moment for FDJC as it begins life!
QB fuse arrived June 30, 2014 and will inventory next weekend.
Exciting it is.
Next will be the finish on the tanks needing proseal and close up after pre cover inspection
