Davids Web Site
Date:  9-23-2012
Number of Hours:  2.50
Manual Reference:  ection 7
Brief Description:  installing the Capacitative fuel quantity sender
Modified the 437 bushings and then solder and crimped the electrical solder connections together.
Also looked at the flanges for the tank filler caps and the drains. These seem simple enough and I test fit them into the wing skins. I will do that next and then do the dimpling. Somewhat out of sequence from the manual but making sure that all is done as I go.
Sealing the tank and all the components is just around the bend, need to get working on it more. The weather was so nice all weekend that it was hard to put time to the tasks.
