Davids Web Site
Date:  10-30-2010
Number of Hours:  4.50
Brief Description:  Installing stiffeners to the Rudder right hand sid
Match drilled and dimpled the rudder skin and back riveted the skin onto the stiffeners. Worked good minor error made in dimpling when i stamped a hole were one should not be. The rivet went into the correct hole and some cosmetic prob but no structural problems. The error should come out with a little bondo and paint.
