Brief Description: Finished riveting left elevator
Riveted inside rivets of E-713 to E-701-L. Loosely placed E-714 inside E-713 and gently slid E-702 assembly in place. Riveted the E-701-L bottom half to the understructure. Flipped the left elevator over and applied RTV to the trailing ends of the stiffeners tieing each pair together. Completed riveting the skin to the understructure. Finished attaching E-714 to the assembly. Drilled #30 holes in the bent tabs and installed two MSP-42 pulled rivets per DWG4, E-701-L Tab Bend Detail.
