Damiens Web Site
Date:  3-12-2017
Number of Hours:  4.00
Brief Description:  Clecoing/riveting the spar assembly to the right H
Clecoed the forward spar assembly into the right HS-801PP skin. Clecoed the right HS-708 center rib into the right HS-801PP skin and blind riveted the forward flange of HS-708 center rib through the HS-702 spar channel to the aft flange of HS-707 nose rib. Riveted the right HS-706 tip rib to the end of the HS-702 spar channel. *Note: For the top rivet the bucking bar slipped off of the tail of the rivet and caused denting and scratches in the HS-702 flange as well as denting the rivet hole area of the HS-702 tip rib. Documented with photos and sent them to Van's Builder Support with a suggested repair procedure asking for guidance. Called Van's Builder Support on 2017-03-13 and was told no action was needed. Van's indicated that this joint at the tip of the stabilizer doesn't take any loads. Recommendation was to prime the scratches against corrosion and build on.
Showing damage on right HS-702 to HS-706 joint
Right HS-706 damage
Right HS-706 damage
