Brief Description: Begin riveting the left HS skin-to-spar
Clecoed the left HS-706 tip rib to HS-801PP to help the skin hold its shape. Clecloed left HS-708 center rib to HS-801PP and finished riveting the bottom side of the HS-707 nose rib to the skin. Removed the HS-708 center rib and clecoed the forward spar assembly to the left HS-801PP skin. Clecoed HS-708 back in place. Used prescribed blind rivets to rivet the HS-708 forward flange through the HS-702 forward spar to the aft flange of HS-707. Riveted HS-706 tip rib to the end of HS-702 spar channel. Began riveting HS-702 forward spar and HS-708 center rib to the left HS-801PP skin starting with the HS-708 forward most rivet hold and working aft on both sides. Then riveted HS-702 from HS-708 first to wing root, then to wing tip on both sides.
