Placed and fully paid for a non-standard, slowbuild wing kit. The oder includes the standard RV8 slow build kit with the following modifications: DELETE W-715-1-L (Left wing tip) DELETE W-715-1-R (Right wing tip) ADD IE F-385B (Fuel Sender Left Tank) ADD IE F-385C (Fuel Sender Right Tank) ADD AA6-125X3/4X3/4X15'2 (Longeron Angle 7/8/9 @2)
ADD Fuel Tank Leak Tester ADD AIL TRIM DJ (Ailerong Trim Drill Jig) ADD W-730 (Bellcrank Jog) ADD DUCT NT5/8-50 (50' Nylon 5/8 TUBE) ADD R-411W/O (Fiberglass Rudder Bottom without the light)
Crate date is set for 4/15/2019.
The wingtip deletions and the rudder bottom changes are to allow for the use of the ZipTips Premiere wingtips which have the rear strobe modules in them.
