Today was a hugh day. Got so much done. Both elevators are covered and heat shrunk. The right wing is covered and heat shrunk. Holes are drilled for the ailerons and ready for Poly Brush. Then we brought out the left wing ,installed the last light and prepped it for covering. There isn't one single whrinkle in that right wing and the leading edge is as smooth as silk and no uggly scollop look.
