Thank god we had a drill press for this job. The Axel and Landing gear are tough as Titanium. We used a drill press to do drill the axels. But the Legs themselves had to be hand drilled. We wore out two brand new bits getting the uppers drilled. Doing the toe in and out was easy because the the mounts for the wheel pants (IMage 2) are on the axel at a perfect 90deg. angel to the axel extention. So you just level them up and then tap the wheel gently enough to just move the TOE IN 1 Deg. Then drill the upper leg holes. Be careful not to drill the upper holes to low as the new brace that is at 45 Degs to the leg support can get in the way of putting the nut and washers on.
