Installed wing tip and boxed in the aileron. Installed temp hinges on aileron and checked for 30 Deg. movment up and down Got it as near perfect as possible. Still need to do the ailerons on the left wing and box in the space between the aileron and the wing tip. Be sure to get a 1/8th hole finder because you will need it to do this wing tip.
