Dan & Andrew's Web Site
Date: 6-29-2016
Number of Hours: 2.50
Brief Description: Service Bulletin 16-03-28, Inboard Aileron Hinge B
Today I worked on installing the inboard aileron hinge bracket reinforcement plates per Service Bulletin 16-03-28. Perfect timing to do this as I had not riveted the brackets on yet.
I cut the 4 plates, edged, match drilled, deburred, primed, and installed the bracket plates with clecos. I made sure to note that for the RV-8, the bottom hole in the outboard angle bracket uses flush rivet so I used the deburring tool to make the countersink. All clecoed in place and ready for riveting.
I also removed the temporary screws holding the wingtip lights in place and added the proper countersunk head screws.
Next I'll rivet the aileron brackets in place on the rear spars.
Cut, edged, drilled, deburred, & primed reinforcement bracket parts
Primed & clecoed in ready for riveting
Installed proper screws on wingtip lights
