Brief Description: Pull Nav/Strobe Wires Lft Wing/Lft Aileron Work
I started off today by measuring, cutting, and pulling the 2 hot wires for the left wing nav/strobe lights thru the wing conduit. Worked really well. I then labled the wires nav & strobe on both ends. These wires are 20 AWG per the Whelen directions. Need to order more wire from Spruce...not enough for right wing.
Then I put the wings away and started un-clecoing the left aileron as it had been match drilled already. I deburred all holes on all parts, and finished all edges the same. I then dimpled the left aileron stiffeners.
Will continue work on left and right aileron next session.
Pulled Nav & Strobe 20 AWG wires left wing
Unclecoed, deburred, & finished edges left aileron
