Brief Description: Wing Spar Prep, Dimples and Countersink
Today Andrew and I started by flipping the wing skeletons on the wing stand. Andrew used the air squeezer to dimple the left top and right bottom wing ribs and bottom spars. I used the machine countersing and hand drill to do same sides of wing as Andrew. We primed the machine countersunk holes on the wing spars. Then we used the hand roller to roll the edges of the left and right top and bottom outboard wing skins. Cleaned shop. Next session will be to work on scarf edges, and inspection panel platenut installation on lower wing panels.
Andrew priming the countersunk holes on wing spar
Dimpling the right wing ribs using the air squeezer
Dan rolling the edges of the upper and lower outboard wing skins
