Brief Description: Fuel Vent Lines, Senders, & Test Tank Fit L & R Ta
Today I started off by putting the right tank together with all ribe and parts. I fit, cut, and flared the fuel vent line into the tank. I test fit the w-423 splice plate and noted how much space i had to leave a good proseal fillet between the end rib and the splice plate. I fit all fuel fittings and fuel senders and checked for proper throw and operation. Checked fuel trap doors for proper operation (will need to perform more work on right tank flop door). Performed same tasks on left tank as well. Left tank has flop tube and fuel sender mounted to the baffle.
