Brief Description: More Tank Work, Joint Plate, Stiffeners, Countersi
Today I started by installing all platenuts on the jointplates. Used the airsqueezer for this....worked well and they came out nice. I then cut all of the tank stiffeners using Wiss cutters. After finishing all of the edges, I installed the stiffeners onto the fuel tanks and match drilled them. (see next page photos). I then countersunk all T-701 tank skin baffle holes to the AN-426 rivet depth per the plans. Lots done in shop today! Next session will be to form up the T-407 tank brackets.
