Today I finished match drilling all holes on the right wing tank and baffle. I then match drilled the end z-brackets R1 & R7. After removing the skin and middle ribs, I match drilled the baffke to z-brackets R2 thru R6, After deburring and priming the right tank z-brackets, I installed all platenute on Left and Right z-brackets and final bolted them to the respective wing spar. I need help to rivet the L7 & R7 platenuts to the spars as these rivets need to be bucked....will wait for Andrew to help with that. I'll then be able to bolt on the #7 z-brackets. Next is preping/platenutting the joint plates and starting work on the tank stiffeners.
