Brief Description: Mounted Hinge Brackets to Rear Spar
Today I first drilled out 1 bad rivet attaching the 609 bars to the 603 spar channels, deburred both sides of holes, and re-riveted using the pneumatic squeezer. This worked out fine. Then I mounted the HS-412PP & the HS 413PP hinge brackets to the rear spar. I then bolted the HS-411PP Center Bearing to the rear spar. Did not torque bolts yet and annotated this on the building directions. Bolts/Nuts need to be torqued at 20-25 inch/pounds. Checked all rivets with guage and all ok. Used pneumatic squeezer for all rivets.
Dan using pneumatic rivet squeezer
Left HS-413PP hinge brackets
All hinges & HS-411PP center bearing riveted/bolted to spar
