Brief Description: Work on miscellaneous aileron rib items
Aileron ribs, glued miscellaneous items. Glued left aileron compression rib capstrips. Cleaned up glue on ribs and cut some miscellaneous plywood for a few final items. Steamed another set of capstrips for the center section wing nose ribs.
