Brief Description: Cutting Front Center Section Spar Flanges
Ripped spruce with bandsaw prior to cutting using a taper jig on the tablesaw. Made initial tablesaw cuts on the lower spar flange for the front center section (cs) box spar. The lower center section spar flange has a 2.5 degree (my estimate and not shown as such on the plans) angle cut to match center and noseribs.
