Brief Description: Outer wing panel ribs 1 and 11 various work
Outer wing panel ribs 1 and 11. Created templates for spruce reinforcing gussets where notches are cut for the outer wing panel to center section fittings. Cut the spruce gussets for ribs 1 and 11. Cut plywood for outer wing panel inter ribs 1 and 11. Cut 1mm ply gussets for use over the spruce gussets reinforcing the area around the wing attachment fittings.
