A special jig for outer wing panel rib 3. This jig is being used to hold the bottom capstrip contour while the 1mm plywood with the lightening hole is epoxied. The capstrip contour changed slightly when the rib was removed from the gluing jig. The gluing jig was oriented the opposite direction and could not be used for this step.
