Brief Description: Center section and outer wing panel ribs5.
Cut openings in 1mm plywood for left center wingwalk rib CML01B. Epoxy 1mm plywood on CML01. Coat hidden areas of left aft area wingwalk ribs with System Three clear coat epoxy. Create bending jig for outer wing panel rib 1 and rib 11 center section top capstrip. Steam bend top captrips for rib 1 and 11 of outer wing panels.
1mm Ply glued on CML01B
Left aft wingwalk ribs coated with System Three Clear Coat Epoxy
