Brief Description: CMR01 and CML01 Trim 1mm plywood
Removed clamps from CMR01 and CML01. Then rough trimmed plywood with scroll saw and fine trimmed contour on router table.
Cut capstrips and glued aft rib for a left wing walk. I am adding wingwalk ribs on the left side. The original only had these on the right side. I don't want my foot or someone else s accidentally punching through the plywood since there are "doors" on both sides of the open cockpit.
Clarke removes clamps from CML01
Additional wingwalk ribs for left side, all capstrips should be 3/8"
Time to loose weight I'm 7lbs over my Chilton pilot weight
