Work continues on center section ribs. Trim a center section nose rib plywood. Add corner gussets to center section ribs. The original Chilton center section ribs did not have gussets. The rebuild of G-AESZ had these gussets. As the weight is negligible I am also adding these gussets to strengthen the capstrip joints.
