Install schematics for Oil Temperature, Oil Pressure, CHT, EGT, Volt/Amp and Tachometer. Install competed per manufactures specifications.Installed each instrument in front and rear panel to determine if any electrical was needed and connected same. Checked the entire system for any problems and corrected as needed. Removed all instruments and returned panels to Barry.
