Meanwhile, Skip has been working on covering the gear. The gear is kinda an odd shape with protrusions at the bottom. This made it difficult to cover neatly. The right gear has two hoses sticking out, one the brake line and the other a oil escape line so oil does not get all over the bottom of the fuselage. Rib stitched two braces that were in each gear. Took some time fitting snd cutting the fabric, but they look pretty good.
