Skip's Web Site
Date:  5-16-2018
Number of Hours:  91.00
Manual Reference:  Poly Fiber Manual
Brief Description:  Still covering process (shrinking the Fabric)
We started the shrinking process. Start with 250 degrees. Start at each end of the wing and work to the middle. (works great) Then at 350 degrees repeat the process. (neat) The outcome is very rewarding.If you shrink with heat over 350 degrees (say 375/400), the fabric could get permantely loose.
looking forward fro aileron bay
From the wingtip
From the wingtip
From the root end
From the root end
