"Today I studied the plans some more to understand the rivetting and bolt requirements for the spar. I have identified and marked on the metal the rivets that need to be flush, which holes are bolts and which holes are not to be touched.
I started drilling the holes up to the 5/32 inch size along the spar and its attachments. I have had to do this carefully as I do not have the 5/32 clecos but it is ok fro the tip to the multi layed web parts. I have ordered some clecos and will do the main part of the spar when I have these so i does not get out of alignment. The bolt holes are even bigger up to 3/16 size and some of these have normal heads while others are also flush mounted
The flush pieces have to have the heads dimpled into the spar web to fit the rivets and flush screrw heads. I have had to order some dimple head pieces to be able to do this. They will arrvie at some point. I have some flights coming up so I will not be gettgin much done on the project anyway. A bit here a bit there.
I can appreciate how Noah felt making the Ark, and the comments he would have had made to him. 'So when are we going flying this weekend Rich?' so I say, 'Sure anytime you like just bring your plane along too and we will both go do some formation. Are you up for it?'"
